rb25det in the S-14
DriFt3r
Car: Racing and Drifting
I have used the search button but I've only found info for the S-13. How different is it between the two and what parts would I need or have to move around to put the rb25det into the S-14? Will the front sway bar clear the oil pan? Would I have to modify S-14 drive shaft or use the skyline shaft? thanks
FAST-DATSUN
Our Kit fits both, only the drive shaft is different, I do not know about using the stock Skyline crossmember as we do not use them.....Check with Night77 or Dautt
HotWIRED
As for driveshafts, the S14 is too short and the yoke is smaller then the RBs. You can modify the RB's driveshaft to fit, but you'll have to shorten both halfs. The RB25 does clear the sway bar.
FAST-DATSUN
A one piece drive shaft is your best way to go... Several companies besides us have them and a local shop maybe able to make one for you also..
