rb25det in s12??!!
drftnassmofo
Car: 84 s12 ca18et-TRADED
85 s12 ca18et-SOLD
92 fastback-SOLD
91 fastback-SOLD
90 coupe KADE swap-SOLD
06 Infiniti M45
does anyone know of anyone who has done this swap? im going to be ordering my rb in 3 weeks. bodywork is being done right now but im just wondering if the mckinney mounts for the s13/rb will work for the s12...and if anybody has any other words of advice that'd be great..ill post pics after the engine bay is painted.
Gold Digger
Car: Current:
2011 Infiniti G25X
Former:
1995 Nissan Skyline GT-R V-Spec Midnight Purple
1990 Nissan Laurel Club S Turbo Two Tone Pearl
drftnassmofo wrote:does anyone know of anyone who has done this swap? im going to be ordering my rb in 3 weeks. bodywork is being done right now but im just wondering if the mckinney mounts for the s13/rb will work for the s12...and if anybody has any other words of advice that'd be great..ill post pics after the engine bay is painted.
Ganbate Gaijin-san!
Other than that, I really don't have any idea on weather or not an RB will fit in an S12.
Vkoslak
Car: 1992 240SX SE rb26dett, 2004 Subaru Forester
its going to be a tight fit. Im pretty sure there is less room front to rear under the hood of the s12 than the s13. Also, I dont think a sr20det or ka24de just bolts into a s12, so you will most likely need custom made mounts and drive shaft. If you keep the power steering, you're probably going to have to move the radiator forward somehow. I have a koyo racing radiator in my s13 and I can barely fit my finger between the pully and the radiator.
Thats my 2 cents. I make no guarantee for its accuracy.
check out http://www.club-s12.org/ for s12 specific info. (no s12 luv on nico)
I used to drive an 85 200sx xe from time to time. Much fun.
S12_hybrid
Car: 1987 Nissan 200sx
It is possible. I am in the process of doing it. Look on Club-s12 under "hybrids" and there is a thread I started on it.. I am also swapping out the rear subframe/diff for a 240 one.. Which is no easy task.
Major problems:-Obd1 -vs- Obd 0-Transmission tunnel is not large enough for RB25 transmission-Speed signal is mechanical in the S12-Crossmember will not work, you will need either a skyline one or a 240 one (requires widening of bolt holes to fit into s12 location.-Engine must be installed from bottom
From what I can see the shifter will line up, and the wiring shouldnt be TOO bad.. I am using the s12 lower engine harness, but am having to adapt a few relays (mainly ignition) to suit the RB25... Keep an eye on CLUBs12 for updates..
-Dan
S14-NEO
Car: 1995 nissan 240sx RB25 NEO powered
well if the CA18DET will bolt in an S12 which i know it will than i dont see why a SR20 or a KA wouldnt bolt in wither for that matter. as for an RBmight be able to score some mckinney mounts and make them work for swap.
S12_hybrid
S14MARKSR wrote:well if the CA18DET will bolt in an S12 which i know it will than i dont see why a SR20 or a KA wouldnt bolt in wither for that matter. as for an RBmight be able to score some mckinney mounts and make them work for swap.
Did I not just explain that it WILL fit with modifications?
Another problem I forgot about is the steering column, and the fact that the downpipe litterally touches it. You need a custom downpipe FROM the turbo.
-Dan
PS- I used core performance mounts. But you could likely use stock mounts and an R33 crossmember to make it work on a budget.
