rb25det in a 240sx? hard?
gabe_768
Car: 97 "S14" 240SX w/ blacktop sr20det
is there anything speific that would need to be done into a 89' hatchback besides motor mounts?
thanks for the help
!Zar!
Car: Countless.
Psyco Performance package which has the driveshaft, mounts and crossmember.
After that you just need the engine.
Wire it up and you're done.
the converted
Car: '99 BMW M3 6.0
'88 Toyota Celica All-Trac (somewhere in Cali)
'20 Toyota Tacoma
Check out the RB sub forum, they will have all the answers that you need in there.
SullivanRacing06
Car: r32 gtst, 06 350z, r32 gtr, rs4 steaga, 04 350z, f350/6bt
for a basic swap from the back of the delivery truck to your car
motor n trannys body rb mount kitrb25 one piece drive shaftwiring harness sent out smic or fmic set up (if not included w swap)
u really need to replace the, water pumpt stattiming beltidler and tentioner pulleyclutch n flywheeltranny fluid good oil fliter (no fram!!!)
and a nice thick core rad w electric fansyour looking at a couple of thousand for a good reliable swap to a rb, rbs are money pits! trust me, when running correctly they are fast and when not running correctly there a pita and a money pit.
have u looked into turboing the ka? or doing a dohc swap and turboing that?
!Zar!
Car: Countless.
That won't get the ladies panties wet if he tells him it's just a stock motor turboed.
It's all about getting the women to drop the panties.
