thanks for the input guys
Paul Wall wrote:Try cleaning the Idle Air Control Valve and the rest of the intake if your up for it. The IACV (Solenoid) doesn't really fail but the body of it does get dirty on the inside.
what i've done already was clean the rb25 one but had no luck. then i went to the junkyard and snagged one from a sentra, cleaned it and bolted it on, it was little bit better, but not anywhere near perfect. I've thought about taking the whole intake mani apart but the thought of sourcing gaskets and what not from here in hawaii.. bleh.. you get the picture
so i have a few updates..
i had a feeling that the maf wires (thanks to a repair made using unshielded wire after the maf wires drooped down onto the exhaust mani, melting the wires, creating a short and frying the ecu) were a part of the issue. So I took the shielded wire from my friends old harness that i had laying around after doing his SR swap and I wired in a z32 maf that i picked up cheap locally. I replaced the wire all the way to the ecu just to make sure that none of it was unshielded. I didnt forget to change the settings on the SAFC2 to accommodate the z32 maf. I also picked up another stock ecu just to rule out the ecu as a problem. Then i checked the fuel pressure and it was on the dot.
Started her up and right away it seemed to run a lot better, so right off the bat i know the shielded made a difference. Right at start up it was running at stoich AFRs, but as it warmed up it got progressively leaner. By the time it was fully warmed up, the AFRs were hovering way lean around 16s. I put the settings on the SAFC2 back to stock but still really lean. So i started messing around with getting the idle down. I unplugged the IACV and got it down to 700rpm and set the idle to 15degrees, but still no luck.
So I just figured that because the z32 maf, even with it hooked up to the SAFC, would still need to be tuned (or am i wrong??) and i wasnt up for it. So I went about wiring the stock maf back in. But of course, I was getting the same exact AFRs, with no change to the timing and idle from before. So I figured I would see what it would take to get the AFRs back to stoich and i ended up having to add 11% to get it there.
I'm kinda lost now. I have a set of ngk bcpr7es-8 waiting to be put in but i doubt that will make any difference.I'm kinda starting to think my CAS or belt is off, but i'm thinking positive and hoping that i'm just overlooking something that you guys can help me out with haha. again thanks for the input. lmk what you think now.
