rb25det help need
240sxr33
Car: Cars (imports)
hi i got an rb25det in my s14. I drove it today the first time.There is a problem the fuel cuts off when the boost comes on.
JonPowell
Car: Cars, Music, My family
I doubt that is what really is going on, why do you think that?
240sxr33
Car: Cars (imports)
it might be in limp mode because afm might be damaged
JonPowell
Tell me what the car is doing...dont leave out any details, and if you have any mods, list them.
240sxr33
Car: Cars (imports)
stock turbo, front intercooler it is rb25det
it just want rev passt like 3000rmp I think it might be because the computer doest recive the air folwinput. My wiring was done by mckinney.
What you think it might be afm im geting a new one on monday
eh?
check your afm voltage at the ecu harness.
JonPowell
Air flow meter sounds like it might be your problem. If you are in need of one, I have an old one laying around. Is your car series one or 2? They have the same signals, just different plugs.
240sxr33
Car: Cars (imports)
thanks for help i will wait for the new afm and see if its going to fix it
I will post some pictures of my car next day with my front custom intrcooler
Thank you powell
Toad[^_^]
By chance are you running the stock fuel pump? I ran one for a week or so and had VERY sluggish response
240sxr33
Car: Cars (imports)
no im running walbro fuel pump.
im still waiting for the maf
how can you check the voltage in maf?
JonPowell
check the output wire for between .5 and 5.0 volts
Joe
why not the obvious guys?
vacuum leak. ill bet you have an intercooler hose thats disconnected or has a leak.
JonPowell
good idea, even though thats a boost leak, not vacuum, but good idea anyway.
What an *** I am, huh?
Joe
blah boost vacuum stfu! you know what i meant Jon ;)ive been at school since 6am give me leeway
JonPowell
HA HA, just bustin your balls man, still was something I didnt think of EVEN IF YOU WERE at school since 6AM.
240sxr33
Car: Cars (imports)
I am 100% sure that I have no boost leak.Here is the picture of my engine.:cool:And does anyone know where that wire in the left corner go?
240sxr33
Car: Cars (imports)
It is this plug.?
silline
Car: drift n
sorry i kno this dosent have any thing to do with your problem but where did you get your hot and cold pipes
240sxr33
Car: Cars (imports)
i made them my self with some new pipes and the ones from my clip
240sxr33
Car: Cars (imports)
there is a 12 code flashing it is a maf right
hey JonPowell i have a series one engine do you still have that maf and how much you want and it works for 100% if not can i return it.
BoostFab
Car: S13cp, S13fb, S14z
240sxr33 wrote:It is this plug.?
that look like the plug for the maf.
JonPowell
Ir works 100%, I have a series 2 maf, same signal different plug. If it doesnt fix your problem, return it and I will return your money, minus shipping of course....I have the plug also you will need to change the plug. I personally would first double check your wiring. You may have made a mistake when extending the wires and mixed them up, it happens.
240sxr33
Car: Cars (imports)
ok here it is we wired a safc2 today to my car and the safc shows thaht airfolw is 0 every thing els works
we did the manual wiring
what it is it maf ?\
JonPowell
I would check that the power wire for the MAF is getting power, that the ground wire is indeed a good ground and that the MAF is showing between .5 and 5 votls on the signal wire.
THEN if that is all good, I would check the MAF signal wire at the ECU and make sure taht I have the same signal there.
If all is straight, power and ground wise, and still no signal, then you need a MAF.
fly240
Car: nissan 240sx
sorry to be stupid but, where is the maf located. Isn't it the one behind the air filter.
silline
Car: drift n
yup thats the one Mass Air Flow sensor
240sxr33
Car: Cars (imports)
hey jhon i think thath the problem is my ecu
ok on my ecu there are #MEC-R281 23710 05v61
i found that on the other forum that this ecu is from bnr32 that is gtr?
could this be a problem?
http://www.skylinesaustralia.c...erial
hey jhon can you tell me what ecu is that
JonPowell
23710 05V61 is no good...23710 05U61 is for an RB26DETT R32
240sxr33
Car: Cars (imports)
so i need to buy a new ecu right does anyone have one
