RB25DET Header flanges
240Z TwinTurbo
Car: 2006 EVO IX, 1991 NSX
I had some header flanges made for those folks who want to fab their own turbo header. These are 3/8" thick cold roll and are cnc laser cut.
frosted flakes
any pics i might be interested in purchasing some...
Yellow4g63
Car: 95 Nissan RB20 240SX RB20
91 Nissan NX2000 VE power
95 Nissan 240SX Stock
Yeah pics and how much?
BoostFab
Car: S13cp, S13fb, S14z
Yellow4g63 wrote:Yeah pics and how much?
im interested
240Z TwinTurbo
I just had a batch of RB26 flanges completed and the RB25 flanges will be done tomorrow and I will then post a pic and give a final price.
cvc9216
How about stainless?
BoostFab
cvc9216 wrote:How about stainless?
SS warps too easily...
Yellow4g63
BoostsFed wrote: SS warps too easily...
Really never heard that before.
BoostFab
try tig with 3/8" 304 stainless without preloading it, you'll see what i mean. as far as after welding wise, it's all said and done no warping after that, some if any.
240Z TwinTurbo
Most header manufactures suggest that you use cold roll steel for the flange over SS because of thermal expansion. You will always get some degree of warpage when welding, but there are techniques that are used to draw heat out of the flange. You must typically use a large flat sander to have the flange decked when the header is complete. Here is the RB26DETT flange. I should have the RB25DET flange pic tomorrow.
BoostFab
i believe the rb25's and the rb20's have the same pattern. price please!?
240Z TwinTurbo
Imissmyturbo
Car: Car's, Turbo's, sking
I would like one for the RB25. What's the price?
cyris3d
i need an RB26 flange stat!.. price?
Yellow4g63
Yeah whats the price for the RB25/20 flange?
74260zt
Car: rb26powered early 74 260z car
You guys need to email James direct, you may get a responce [email protected]
PSSHHGOESMYSR20
Car: 1991 Turbo Sentra SE-R
Stainless steel does have the tendancy to pull ( warp ) more than mild or carbon steel. The reasoning behind this is because stainless is a stronger material, the molecules are much tighter within the material than in carbon and mild steels. But to not use stainless because of this simple vice would be misuse of a valuable resource. If you use the right steps during the process of welding a manifold/header, the flange will not warp at all. Both 1010 mild steel hot rolled and 1018 carbon steel cold rolled will warp a good amount themselves if not welded using the right process. Our company uses 1/2 inch thick 304L CNC cut flanges on our equal length manifold's ( http://www.protech-fabrication.com ) and have not had any issues with warping or shearing of the studs as some claim. When building a manifold or header it is always best to use similar metals as opposed to disimilar metals. When you use a mild or carbon steel flange on a stainless header with out coating it, one day you will pop your hood to see a rusted mess sitting atop a beautiful header, if it's welded properly during the delution process. Just food for thought.
accel junky
I need one. Sent email.
[email protected]
BoostFab
just making sure: are the flanges for rb 20/25/26 have the same pattern?
74260zt
25 and 26 are different....
Dramier
Car: 76 Datsun 280Z
*bump*
Sent you an email. Thanks for making all of these parts available to us.
goofynick6
Car: 1995 S14.5 RB20DET
I need a new metal header gasket for my RB20...anybody got a place where I can get one?
Thanks!
Yellow4g63
goofynick6 wrote:I need a new metal header gasket for my RB20...anybody got a place where I can get one?
Thanks!
I just got the stock one from Mckinney. I dont think anyone makes one for them.....
goofynick6
$80 yikes
240Z TwinTurbo
goofynick6 wrote:I need a new metal header gasket for my RB20...anybody got a place where I can get one? Thanks!
I am having some individual copper gaskets cut for this project and will post some pics when finished. I can make them available to those who need them. $80 is ridiculous just as paying $300 for a $170 rear sump RB20 oil pan is ridiculous.
goofynick6
Keep me informed. I was thinking of having some copper gaskets waterjetted at the local machine shop from a scanned manifold, but I wasn't sure if just a flat piece of copper would work, as stock gaskets have that raised ring around the ports that helps them seal better.
Nick
HotWIRED
Are you going to make the intake manifold gasket also?
240Z TwinTurbo
HotWIRED wrote:Are you going to make the intake manifold gasket also?
How much do you currently pay for them?
