Darius »
https://forums.nicoclub.com/darius-u5470.html
Tue Dec 30, 2008 6:17 pm
Why the eff did you cut your valve stems to 42 and 47mm? Are you talking about the valve guides? There is no way your valves are only 47 mm long unless you are doing some crazy solid lifter conversion. That's less than 2 inches long.
You must be talking about something else because this doesn't make sense.
