Rb25det Harness
Streetracer-22
Car: Nissan 200sx (S13),Rb25det swap package
Hy there !
I have some kind of problems....my rb25det swap isnt going to start..
The Engine Harness was cutt of on one position and im not sure which electrical part was attached there..
The engine revs...but no spark+no fuel injection...
Making some fotos (sorry for bad english) didnt practiced a long time
Streetracer-22
http://streetracer-21.gwebspac...2.JPG
http://streetracer-21.gwebspac...3.JPG
http://streetracer-21.gwebspac...4.JPG
http://streetracer-21.gwebspac...5.JPG
http://streetracer-21.gwebspac...6.JPG
http://streetracer-21.gwebspac...7.JPG
http://streetracer-21.gwebspac...8.JPG
http://streetracer-21.gwebspac...9.JPG
http://streetracer-21.gwebspac...0.JPG
http://streetracer-21.gwebspac...1.JPG
thats all my problems...sorry if im worring about simple problems..but im loosing my mind at these things...
240z4u
Car: '95 Nissan 240SX
Okay that ratsnest in the first photo looks not too unusual.
Why are you trying to use the skyline fuse/relay box?
The cas looks fine, along with almost everything else.
If you can't figure out what a wire is trace it back to the ecu and check the pinout.
The brown thing is the wiper amp from the skyline (or your car) I can't tell exactly what I am looking at.
The brown thing with all the wires is a ground distribution setup.
Gray wire tied to all the injectors is +12v power I THINK!
Those splices are factory.
Those two relays are factory.
Evan
Streetracer-22
´thx man !
waiting on more replies.....or i have to "puch down" my importfreak...called http://www.importcars.at...for seeling me this "Freakshow" of harness
SIL-LINE
Car: S-13 With RB20det
This looks like a job for Carl H!!!!!
Good luck !!!!
Streetracer-22
SO after HOURS OF WORK , i solved all wiring problems....yesterday at 21:30 (european time) the motor has its first start ..everything ok..
some oil throwout at the turbocharger hit my face buts ok....im justhappy hes breathing !
Thx you all !,...going to make a video of it .
BigC_1988
Car: Nissan Skyline R32
I have the same problem...I have spark but the injectors arent spraying. I checked the plug that goes on the injectors and the grey wire give 12V but the signal wire from the CU give 0.03V. I know this is to low but what could the problem be?
