Toad[^_^] »
https://forums.nicoclub.com/toad-u6768.html
Mon Jan 03, 2005 10:01 am
I have a stock RB25DET in a '93 240sx. It idles fine around 1k rpm and there are no vacuum leaks. I have a boost gauge hooked up and I'm pushing 7 or 8 psi between 3k-4k rpms. The problem is that when I apply full throttle pressure the car won't pull over 5k rpms but if I back off to half or less throttle it pulls like normal. I have copper plugs in now and I'm going to switch to iridiums today. The engine also runs very warm. It has overheated int the past on a hot summer day while sitting in traffic on the freeway but with the cold weather it is still running warmer I would like. I don't have a temp gauge hooked up so I can't get an accurate reading. Any suggestions?
