RB25DET gearbox info needed
Jason3249
hi all im new to this forum hope this is posted in the right place
iv got a conversion going on but
iv got a RB25DET skyline engine in it
the problem i have is the gearbox
dont know what one to get as need it to be rwd only
is there a gearbox what will do the job
thanks all :)
OriginalWheelman
Car: '15 Ford Focus Electric
Use a VG30DETT transmission with and RB25 bell housing. The guts are the same. In a pinch, the 240 gearset works. It is not strong enough to hold up to the RB's torque for long, but it fits in the RB20 case.
But if you don't have a transmission at all, you still need a bell housing, and a transmission, and might as well just find an RB 25 transmission.
Jason3249
hi mate thanks
i don't have a gearbox at mo
looking at a gearbox but has a transfer box on it
i through a transfer box was to make it 4 wheel drive
im after a gearbox what is a rear wheel drive only
as i cant have 4wd
thanks agen
OriginalWheelman
I'm pretty sure you can use the bell housing from the transmission with the transfer case. but that is an AWD transmission and they can't just separate the transfer case. I still thin your bet option is the RB25 transmission.
