Rb25det (frustrated)
driftersilvia240sx
Car: 350z (business car)
240sx (rb25)
civic eg (winter beater)
Hello guys, this has been brought up multiple times....Rb starts great cold, but when warm will not start back up....
Stock everything
other than fmic, exhaust, i have replaced coolant temp sensor nothing...
It does start to miss fire when warm slightly, timing is spot on... i suspect possibly a bad maf, o2,coilpack, ignitor (S1),fpr im stumped ... out of frustration i bought a Z but i miss driving my 240 so much... If you have any suggestions lemme know...And if theres any additional info i can give let me know
Last edited by driftersilvia240sx on Wed Mar 13, 2013 5:18 pm, edited 1 time in total.
driftersilvia240sx
240sx (rb25)
i plan on working on it this weekend and posting a video of symptoms
Carl H
sounds like classic coilpack/ignitor failure if it only does it hot.
DA 240
Car: 90' 240SX w/ RB25 & HX35
I've got to ask the obvious question, did this start after installing any new parts?
driftersilvia240sx
240sx (rb25)
DA 240, no its always plagued me...Ive been working on this specific car now for 5 years.....and its been a nightmare. Ive had everything that could go wrong, go wrong from headgasket to pistons in the oil pan...Im at the point were i ordered a new long block and bolted up intake and exhaust and everything else and to my suprise its actually running.
So, im so close to driving it i can just taste it...But im having this small irritating problem...ill purchase some coilpacks cheapest ive found were on enjuku brand new for like 68$ a piece...i know spitfires is the way to go but honestly the stock packs should be fine for what i want out of this rb...illl keep you all updated as much as i can
driftersilvia240sx
240sx (rb25)
Anyone in the MI area???
Yellow4g63
Car: 95 Nissan RB20 240SX RB20
91 Nissan NX2000 VE power
95 Nissan 240SX Stock
Get the LS2 coil packs and wire them up. You don't need the ignitor with them.
Darius
Car: RB25DET S14 - 665 WHP (SOLD)
+1 on the coil packs
You will likely want to go the LS coil route eventually, so if it doesn't turn out to be the solution to the current problem, you're not out money and effort.
driftersilvia240sx
240sx (rb25)
Roughly how difficult is it to do the conversion ...I've always wanted to just didn't want to add to the headache ya know
driftersilvia240sx
240sx (rb25)
Ok this morning i started the car let it warm up, all was well :squint: but the car will not start back up under warm condishions... This weekend im pulling sparkplugs to see if they are satcherated in fuel...If so do you think coilpacks???
95_240
Car: 1995 240sx
Have you tried cracking the throttle when starting?
driftersilvia240sx
240sx (rb25)
i use to i dont have to any more (on cold start)...On warm it doesnt help ill get some sputtering but thats it...But it does start without throttle
driftersilvia240sx
240sx (rb25)
http://www.rad240sx.com/2011/10/ls2-tru ... 2-rb25det/
alright guys found this really good write up, im thinking of tackleing it...Did my own harness so how hard can this be right :) only thing im curious is why would i have to run a aem,apexi power fc ect??? cant i just run off of stock pcm???
mixeds14
Car: 240
U don't have to run a stand alone to run ls2 coils.. Ur stock ecu works just fine, that's what I'm running now.. Believe me it's super easy to wire them up n u thank ur self for doin it. My idle improve as well with the coils.. I believe u have to run a stand alone to get the full potential out of the coils.. But they work fine as is
Try this diagram on the coils, just match ur stock to the ls ones..
http://www.megamanual.com/seq/coils.htm
driftersilvia240sx
240sx (rb25)
This may sound stupid but do i still have to run the ignitor i skimmed threw...im not sure..
Thanks Mixed :dblthumb:
mixeds14
Car: 240
driftersilvia240sx wrote:This may sound stupid but do i still have to run the ignitor i skimmed threw...im not sure..
Dont thank so, Ls coils have it built in
driftersilvia240sx
240sx (rb25)
yeah, one more thing from the Stock ignitor pigtail to new LS harness do you just mate them together...By cutting and soldering?
driftersilvia240sx
240sx (rb25)
Alright guys purchased my ls2 coils 38$ a piece lifetime warranty...
Im still at a fork in the road though, most of the write ups are for a S2...Myself i have a series 1 to bypass the ignitor what do i do???
Yellow4g63
Check the LS2 coil wire up on the forum. Prob have to search for it might be a few pages deep by now.
driftersilvia240sx
240sx (rb25)
assuming this is correct i havent looked at my rb all day pulled this from a thread...
Sil240 wrote:Wires that go into the Ignitor, in the firing order:
1) Blue/Orange
2) Blue/Black
3) Blue/Red
4) Blue/Yellow
5) Blue/Silver dots
6) Blue/white
jbracy7
Car: 94 GTS TYPE-M in a dozen pieces
I also needed that info thx a ton,i kno its lame but,are u using 90+ octane
Darius
Check out page 1 of this thread towards the bottom:
my-ls2-ls7-coil-swap-t353832.html?hilit ... %20ignitor
"The stock ignitor is wired in order of firing order and not cylinder number. So, pins A-F are wired to cylinders 1-6, respectively.
1) L/O
2) L/B
3) L/R
4) L/Y
5) GY/B
6) P/W
driftersilvia240sx
240sx (rb25)
Daaang it Darious thanks anyway i just pulled a wiring schematic and just did it on my own....But anyways Success guys I did it!!!! I will post pictures when done kinda looks like a mess right now but fires and GREAT!!!
driftersilvia240sx
240sx (rb25)
All in all i did find my real problem looks like i had japanese mice chew up bits of my coil pack harness no wonder why it was missing....But all is well thank you guys so much
