Kansei240sx »
https://forums.nicoclub.com/kansei240sx-u21658.html
Thu Oct 09, 2008 3:10 pm
Start disconnecting everything along the path of the positive battery cable until your large amp draw goes away which is causing your **** to melt. As you go along the line disconnecting different circuits try it one at a time, and hook the cable back up. If you've hooked it up and the cables no longer get hot, you've isolated your problem.
Where is the negative battery ground located?
When you have the power wire go to the front for the positive lead on the battery, how do you have everything else powered up?
Does the power wire connect directly to the starter power wire, fuse box and alternator power wire? If it is, the power wire from the alternator needs to be ran through the fuse block.
You need an alternator ground, battery neg - ground, fuse block ground and ecu grounds.
P.S. I know he doesnt have perfect grammar, but even i could understand what his first post was about, you dont have be such douchebags about it, maybe if you got past bitching about something retarded and tried to actually read it you might be able to contribute something to someone who needs help.
