I put it back in and drove it home, i was only about 3 miles away. when i get home i take off the coil cover and the inner valve cover had leaked a lot of oil into the spark plug galleys, one got so bad one spark plug was like 90% submerged in oil. I figure this is why it bogged and not running the same, plug probably not firing or not as strong because all of the oil.
Thinking about what happened lead me to believe the pcv valve had let boost into the valve covers, causing them to leak oil and pop the fitting off. Take off the pcv and blow into it and indeed it lets quite a bit of air through, and thats just with my mouth so imagine 20-22psi of boost that i was doing allowed a lot of high pressure air through.
At this time i noticed oil leaking through a coupler for my ic piping. Took it off and theres quite a bit of oil in my intake tube to the turbo and my intercooler pipes. Id guess the pressure forced oil to the vent tube to my intake, went through the turbo and into the pipes.
So i have it all cleaned up now from all the oil and im going to pick up a new pcv and grommet today and put it back together and see what happens.
So finally the big question... what damage could have been done? Anyone know the part number for the pcv and grommet? After what happened im definitely putting in a catch can and im debating deleting the pcv all together and plugging the hole in the valve cover and capping the vacuum feed to it on the intake manifold. Hoping nothing major but i have the worst luck with my rb so im preparing myself mentally for the worst... let me know your opinions. Thanks in advance and thanks for reading.
