We are in a process of swaping the RB25DET engine into the BMW E30 chassis. We are working now on wiring harness. We use this ECU diagram:
Could you tell me which ECU pins should get 12V to start the engine and run properly? I assume we need deliver 12V to pins: #49, #58, #59 and #109. What about #43 and #45 pins? Please correct me if I am wrong. Should we deliver to #43 pin which is Start Switch 12V voltage while cranking?
I also have 3 pictures which I want to show you.
1. What is this thing in the red circle? Where does the harness from the white plug go (the yellow circle)?
2. Where does this plug go?
3. Where does this plug go?
Thank you.
Michael.
