Rb25det Ecu Help?
iam2pro4u
Car: 1995 240sx rb25
Hi ive been searching and searching and cant seem to find the right rb25det series 1 ecu pinout. Ive found so many that turned out to be the wrong ones. Does anyone have a link or anything to help me out?
kevwa
Car: 95 Chevy S10 RB25DET
this is the one i used - good luck
http://paulr33.skylinesaustral...t.pdf
S13 240SX
Car: 93 Mazda Miata
that link looks to match the pinout i have for my rb20 as well...
someone correct me if i'm wrong.
iam2pro4u
Yes thats one of the ones i tried and it was the wrong one.
S13 240SX
Car: 93 Mazda Miata
pretty sure its the same man.. what are you trying to look for thats not matching what excatly are you doing, re-wiring?
iam2pro4u
I was trying to hook up a tach directly to the ecu. Cause my stock cluster one doesnt work. But using the pinout everyone is giving me (same one u said) it doesnt work.
s13point5
Car: 89 240sx
in the r33 (rb25) FSM there is a pinout on page 265. you can download the fsm over on racebread. the adobe page for the pinout is 286 (265 in the actual fsm). its slow at work and so ill try to help out a little bit. here are pictures of the FSM
iam2pro4u
I figured out which one was my tach signal and on your pinout above its number 57. Which on your listing is saying thats the exhaust temperature sensor signal. So this cant be the right one for my ecu.. As far as i know i have a regular r33 ecu. Is the ecu any different if its automatic?
