JCAP_Tuning »
https://forums.nicoclub.com/jcap-tuning-u9361.html
Thu Sep 18, 2003 4:16 pm
What I am using is the KA lower harness, RB engine harness and s14 dash harness, to use the RB gauge cluster and dash harness you have to remove the dash and that was not the route I wanted to use. I recommend going the same way I am, but it is an opinion.
But to answer your question, yes you will have to modify the engine harness and also the lower harness (plugs into transmission sensors and power) if you go the route you spoke of.
