Rb25det dump pipe clearence
TheRBguy
Car: S13 240sx Rb25det swapped
I have a series 1 Rb25 swapped into an s13 sitting on mckinney motorsports mounts. I changed my exhaust manifold today to an aftermarket one and it messed up my clearance between my dump pipe and steering shaft. I found this one below on ebay and i was wondering if this would solve my problem, or if anyone knows of somewhere else i could get one could you please let me know. Thanks
TheRBguy
No one has used an aftermarket dump pipe in an s13?
StricNyne
fitment issues on bolt holes, and thats larger than the oem dump so its safe to assume it wont fit
TheRBguy
Do you know of any that will fix my clearance issue?
StricNyne
nothing :( u can hack that up OR try those screamer pipes and hack that up a bit, i would think the screamer pipe
TheRBguy
Hmm i guess i could try that.
Gabes13
Car: rb20det s13
The clearance issues with those elbows is from the wastegate tube hitting the steering column. A member on here, CA18magic, tried installing one on his 20 with tophat mounts and said it wouldn't fit. You can try, but I don't think it would work. If you have the cash, Part Shop Max has a complete elbow/downpipe that addresses that issue.
TheRBguy
I have mckinney mounts and it use to just rub a little bit nothing major when my engine rocked but i changed my exhuast manifold now it seems to be closer.
Gabes13
Car: rb20det s13
I guess there's a couple of things you could do: 1. ditch aftermarket manifold, and go back to stock manifold. 2. Try to file down all the mounting points a millimeter or 2. Try to hack up an ebay elbow. 4. Make your own elbow. 5. Buy the PSM unit and cross your fingers.
TheRBguy
Ok thanks for the input. I might see what i can do with an ebay one and see if i can make it clear.
ItzGenX
Car: Smoke Purple 95' S14.5. Powered by the "Iron Man".
I've seen some aftermarket elbows 'hammer fitted'. Stock elbows are simply grinded away since the castings are so thick.
