Correct, that was my old school 240Z with the 280zxt motor in it(check my signature). The current car I am working on should run close to 140mph.DETurbine wrote:I don't understand.....you are doing a manifold for this project...and still not done with it?...but you ran a 10.62 on it?....or are you talking about the 240z with the L6 twin turbo that you have?
Don't want to reproduce them, as there are variables that can cause a manifold not to fit. I can do more, but I require the car to be with me. I have one more tube to go and have about 10hrs in the manifold thus far. However, two of those were spent milling the recesses in the flange so the tubes can set .150 into the flange before welding. This provides a stronger joint. The turbo will also be braced to the block to stop vibration and to take the load away from the tubes.wawazat8402 wrote:I love where it places the turbo. Are you planning on making custom manis or is that your last one? It looks awesome!
Correct, Big Kahuna turbo that I sell with p-trim .58. Setup should generate atleast 550hp@wheels on stock longblock(~20psi).DSMs_Suck wrote:having trouble making out the flange... u going straight t4?
you would need an oil catch can.wawazat8402 wrote: i really dont like the thought of oil feeding into my intake.
Not yet hooked up. It will run to a catch can that is plumbed to the inlet of the turbo. This will create a vacuum on the block under boost, but no allow the turbo to suck in oil. The catch can drains back into the block through a one way check valve(PCV).wawazat8402 wrote:I noticed you removed the line that runs from the top of the valve covers to the intake. The one that hooks up to what i guess are for oil overflow. Does that affect anything bc i really dont like the thought of oil feeding into my intake.
