RB25DET cylinder order.
leesredgt
Car: 1992 Toyota MR2 N/A
1991 Toyota MR2 Turbo
Okay im having a hard time setting the timing on my rb so im going to rig up a spark plug wire form the plug then to the coil and then pull off of that.So i was wandering and yes this is a noob question but i wanted to be sure before i take it all apart is the 1 coil/cylinder the very first one meaning its closet to the front of the car and the sixth coil/cylinder being all the way to the fire wall or is it in a diffrent order.Ive searched and looked in the fsm but i dosent say unless i missed it.The only reason i ask is on my 3000gt the order of the cylinders are total opposite of what you would think so i just wanted to be sure.thanks guys
Joe
you are correct
Firewall654321Radiator
leesredgt
Ok thanks alot i appreciate it!
