rb25det cuts out at 4000 rpm
EVILS14
Car: 1995 NISSAN 240SX SE RB25DET
when i rev to 4000 rpm my rb cuts out like its hitting a rev limiterand im running the stock 240 fuel pump so im wondering if thats my problem
discosteak
Car: 240sx
sounds like a maf prbloem
shaun.shawn
Car: R34 GTT
change out your coils start at the back
zippakilla
Is it 4000? or 3500? Maf is 3500 for safe mode/limp mode check maf wiring.
Acecool
Car: 1989 Nissan 240SX Hatch Pig KA24E 126k
2500 is limp mode for rbs... which means the maf is not connected or not getting a reading..
Are you able to rev past 4000 while idling, and it just loses power around 4000 to 4500 under load.. if so, it is 100% your coils are dirty, or starting to fail which is a common problem.
Edit:If it 100% cuts out, like wont rev further, it may not be getting enough fuel and you are running lean - fix it ASAP!!!
zippakilla
Thank for the correction.
EVILS14
well my knock sensors aint hooked up so its running rich the retards i bought the engine from cut the wires... i unpluged the maf and it had no effect on the idle at all
EVILS14
im sorry it is 2500 my tach was way off
Acecool
2500 = MAF not connected / cant get a good reading.
Solutions: EitherA: Clean itB: Replace itC: Double check the wiring to make sure it is all connected and not corroded!
EVILS14
fixed it was the wiring.... thanks
guricha
Car: Skyline R33
what kind of problem was it ? could you write how you fix this issue?
