Postby
quikdime »
https://forums.nicoclub.com/quikdime-u35628.htmlFri Mar 28, 2008 5:04 pm
I have a basically stock stock rb25det in my 240sx. It has a front mount intercooler,a test pipe,Nismo fpr (set at 37psi) and 3 inch exhaust. It runs fine. I want to get a baseline on air fuel mixture because I want to install a boost contoller. I installed a Uego AEM air/fuel gauge today. I am not sure if the car is running rich or lean. How do I read the gauge correctly before I turn up the boost? I want to make sure I dont blow up the motor. Thanks in advance
Postby
Carl H »
https://forums.nicoclub.com/carl-h-u9196.htmlSat Mar 29, 2008 3:39 pm
14.7:1 is ideal...lol.
but seriously its dependent on load...under full boost 10.5-12:1 depending on tune is considered safe...nissan stock ecus generally run very rich with afrs in the high 10's under boost.
Postby
quikdime »
https://forums.nicoclub.com/quikdime-u35628.htmlSun Mar 30, 2008 6:15 am
Thanks for your help. I installed a profec b boost controller and took a spin. At low boost setting (7 psi) the reading is around 10.5. Same for the high boost setting (13 psi) is about the same.
