RB25DET cold pipe
jbracy7
Car: 94 GTS TYPE-M in a dozen pieces
what would be needed to reroute the cold pipe from over the valve covers, i dont want to cut holes in my bumper to run a front mount,or hacking up the crash bar, looking for the cleanest look possible Image
Krazykouki
Greddy / Freddy intake manifold.
TheRBguy
Car: S13 240sx Rb25det swapped
A stock intake manifold is the best for power if your motor is not built.
l0nestar
Car: 1993 Nissan 250SX
2004 Toyota Altezza
1963 Chevy Impala SS
jbracy7 wrote:what would be needed to reroute the cold pipe from over the valve covers, i dont want to cut holes in my bumper to run a front mount,or hacking up the crash bar, looking for the cleanest look possible
Well, if you want to change the cold-pipe, yet do not wish to modify the bumper supports or install a front-mount charge cooler.. You are left with a few options. Unicorn tail hairs, Phoenix tears, or Dragon heartstrings. Oh, or a cold-pipe made of Unobtainium. Your question makes about as much sense as "I want to bathe, but without taking my clothes off."
If your heart is set on removing the factory cold-pipe, and utilizing the factory SMIC, then you should invest in a lot of tubing, U-bends,silicone couplings, T-bolts, and a chop-saw. You are going to be spending a lot of time re-inventing the wheel with no gain.
The factory IM (1-6)is more efficient , a 2JZ style (1-2-3x3) provides even better distribution, but the least efficient is the GReddy / Freddy front facing plenum, which provides the cleanest look.
Gabes13
Car: rb20det s13
There are fmic that are side fed. Personally, I don't think a stock manifold with u bends all over the place looks "clean".
jbracy7
.. I see,no, i dont want a spiderweb of tubing,i just dont like the cold pipe over the engine,oh well ill just get over it,my rb is 90% stock the only upgrades that have are mostly dress up items(no rice i promise)like -an fittings, thinking of a wire tuck but i have to put this thing together first.shes gonna stay stock untill i can own her legally in a few more years
