RB25det clutch
JCAP_Tuning
Just want to verify this before I order these, the RB25/20 all used the following z32 n/a parts:
throwout bearingflywheelclutch discpressure plate
I have a chromoly flywheel and used Nismo Pressure plate so I was going to go ahead and order a throwout bearing and Nismo disc from Courtesy.
SHIFT_Lock
Car: kouki s14
thats a negative.
JCAP_Tuning
ok, I thought the clutch was the same as z32?
So, which parts are these equivalent to? I am using a rb25 w/rb20 5spd transmission.
krayton
from what i understand, the flywheel will not work. but the rest will (for the rb25). we had a thread last time about the TO and yes it does work. it isnt the same, but it will fit on the stock sleeve and into the transmission just fine.
heres a pic of the z32 n/a TO in the transmission
click here
JCAP_Tuning
Nice. so I can get the TO bearing from courtesy and the NISMO clutch disc for z32 n/a. I have a flywheel from a rb25 already, only problem is that, the flywheel is lightened chromoly and not sure if it can be resurfaced or not.
