stock placement:
thinner placement (clutch moved to inside the disk):
but why not just notch the radiator more and push it all farther forward? well the answer to that is a PBM HMIC (http://www.gtfactory.jp/cms/e107_plugin ... hp?4008.20) and how damn close they come to hitting the headlights. so i can't just move everything forwards.
Currently i have just under 3.5 in of clearance from where this mounts to my griffin rad, so i figure i will push back the radiator about 1/4 to 1/2 if i can in just to have some play for motor shifting (though the syko mounts don't seem like they have much give in them)
from what i read this should fit (backside clearance) with little to no shaving of fins also i will be switching over to a Freddy IM, HMIC, and this all at once and hopefully it so i should be greatly increasing the airflow to my engine bay with this setup over a lower FMIC, and dual FAL pushers.
so what does everyone say?
*****update 1/5/2012*****
still running great, no shroud on the radiator. I have noticed this winter since switching to a HIMC and doing this that may car not runs too cold, and takes a solid 60-80 min to get the heaters blowing anything more than slightly warm air. (with ambient about 43 or below) which is quite a strange issue for a RB.
