RB25DET CAS question. Anyone got a part number?
vsaini
Car: Turbo Fairlady
I've searched through the parts cross reference thread, as well as a few other forums. I've turned up a part number but i am not sure if it is for the 26 or the 25Neo. I need one for the RB25DET non-neo motor. I think it is the same as the z32 CAS but I am not sure. Does anyone have a part number for it, or does anyone know if they are the same?
Vik
Coolwhip
Vendor
Car: RB26 Raw Brokerage War Machine
the Z32 and the RB one is not the same.
There are essentially 2 type of RB CAS's.
All cast aluminum (star shaped female drive with half a moon key way):RB20RB25 S1RB25 S2 (Pre)RB26 R32RB26 R33
Plastic Black Cover CAS:RB25 S2 (late)RB25 NeoRB26 R34
I have a S1 CAS here in Orlando if you need one.
vsaini
Car: Turbo Fairlady
Yeah its the multipoint one with the half moon key inside it. its a mitsu unit, all AL.
I am not sure if thats my problem or not but I along with my tuner suspect it. I just wanted to swap in another to check to see if the results are the same. Don't know if you'd be down to do a quick and dirty swap-a-roo for a few minutes...
blues14
Car: 1995 Nissan 240SX GTS-t
you can get a brand new one at http://www.nismoparts.com
vsaini
Car: Turbo Fairlady
Right, if it comes down to it i'll source a new one. but for now I just want to check whether or not this one is working correctly
But the issue maybe mute. Why? I am using a z32 Ecu to control my setup, and might try using a z32 Cas as long as it is physically compatible.
imotion s14
Car: 1997 240SX
22131-58S00
8/93-1/95 (RB25DE, RB25DET)1/95-1/96 (RB25DE, RB25DET, RB26DETT)1/96-2/97 (RB25DE, RB25DET, RB26DETT)2/97- (RB25DE, RB25DET, RB26DETT)
22131-58S10
