240slidekat wrote:it could be your fuel thats limiting your power, what engine management are you using?
It wasnt an issue but i try not to go more than 20ish psi on 92 anything more than that is really starting to heat the charge240slidekat wrote:i mean fuel as in the octane but that was just a guess.
It wasnt tuned by a shop, but by a friend of mine who is VERY good at what he does... there wasnt much left, timing didnt change torque much at all and airfuels are dialed..WhatsADSM wrote:While 411 isn't a bad number I do agree it does seem to be a little short on power... Although a drag strip mph would probably be an interesting data point. I've seen some pretty conservative dynos.
Who did your tuning? Are you sure there isn't more left in the tune?
As an aside... a 1.06 T4 turbine housing is pretty f'in huge for a turbo that isn't *that* big. Is it a twin scroll or something? Granted my car is focused on being effective on a roadcourse (i.e. I went for responsiveness), but I actually use a .68 T4 on my PT6262.
As you quoted earlier, tomei pon cams seem to be the most popular choice. I see that you are running a greddy style intake manifold, so how high are you revving her? I would imagine (despite any hard evidence) you would benefit quite a bit from a serious cam if you're spinning it pretty high. You already have great low boost threshold, so why not go with a serious 272 setup? I'm sure you would pick up some ponies with that intake manifold and a nice redline.flatrate wrote: Just wished there were more documented power gains on cam swaps
Good question....i would love to run some 272's or a set of custom 280's. Dont even think its possible with a rb25. Might have to swap in a 26 or 1j/2jz...hehejulio wrote:As you quoted earlier, tomei pon cams seem to be the most popular choice. I see that you are running a greddy style intake manifold, so how high are you revving her? I would imagine (despite any hard evidence) you would benefit quite a bit from a serious cam if you're spinning it pretty high. You already have great low boost threshold, so why not go with a serious 272 setup? I'm sure you would pick up some ponies with that intake manifold and a nice redline.flatrate wrote: Just wished there were more documented power gains on cam swaps
Do RB25's require head modification to run cams over 9.15mm of lift like the RB26's do?
Really? You hit MBT before you hit a knock threshold? Seems a little strange for 93 octane but maybe. Out of curiousity how much timing are you running through the rev-range on 20psi?flatrate wrote:base timing doesnt matter, the engine was tuned to maximum brake torque then taken back a couple degrees for safety, maximum brake torque is reached when additinal timing is added and minimal power is gained.. it was gaining good power 10-13wtq per degree then it vanished indicating it didnt want anymore and MBT was reached...
The 4cyl really isnt a good comparison as the cylinder head is much better than the RB's
the engine is really responsive just wished it made 450 on pump, i have a 35R sitting on my shelf in the garage im debating weather or not to put it on...
Id be happy with 500whp around 25psi... im thinking a set of cams and 5 more PSI will do it.. Just wished there were more documented power gains on cam swaps
Good thing you were watching the plugs at least!flatrate wrote:It was still gaining some torque with more timing, however the gains were noticably lower and the plugs were starting to show very light hints of what i thought was detonation.. could i have gotton a bit more out of it? Sure but its a street car and i want longivity as well, not to mention i tend to rape my vehicles alot. On 20psi its not running as much timing as ive seen most others... ill have to look at the map as im not sure on an exact number but its some where around the area of 12-14 degrees i wanna say... IATs where a bit warm, but theres something to consider there as well the IAT settings that haltech had in there software were off about 20 degrees or so..
WhatsADSM wrote:Good thing you were watching the plugs at least!flatrate wrote:It was still gaining some torque with more timing, however the gains were noticably lower and the plugs were starting to show very light hints of what i thought was detonation.. could i have gotton a bit more out of it? Sure but its a street car and i want longivity as well, not to mention i tend to rape my vehicles alot. On 20psi its not running as much timing as ive seen most others... ill have to look at the map as im not sure on an exact number but its some where around the area of 12-14 degrees i wanna say... IATs where a bit warm, but theres something to consider there as well the IAT settings that haltech had in there software were off about 20 degrees or so..
Yea you might have been reaching peak power due to it starting to detonate as well technically that's not MBT. I would try 2 things:
1) Put in race gas in it, and see what happens when you give it more timing. FWIW I run over just over 20* (at the top of the rev range) on e85 at 20psi.
2) Boost leak check it. I read your thread on rbfourms and you indicated you couldn't hold boost. No way a 3076r should be making 411whp, while at the same time not being able to keep up with the engine. That plus the warm IATs could definately be an indicator of a leak making the turbo work way harder than it should. (Warm air doesn't help with knock resistance either).
20psi is not always the same.flatrate wrote:I found a LARGE boost leak at the blowoff valve as well as a small leak at a couple and a few injector o rings... i wonder what kinda power loss i would get with these leaks... i mean 20psi is 20psi reguardless if theres a boost leak or not right?
