RB25det Build
leekim
Car: 1995 240sx
Ok i dont really know where to start, i need help putting a Rb26 head on my RB25. i'v Been doing alot of SEARCHING but i never seem to come up with a complete answer. I just want to know wat need to be done for this to work. If you guys dont mind helping me out. Thank you
This is what i have so far...
wisco 87mm piston
Eagle Rods
RawBrokage crank collar
ACL bearings
Carl H
you'll need to modify the block for the coolant passageways at the front on the oil filter side of the block, the 25 has a different setup than the 26 and you'll have oil and coolant mixing unless you modify the block or head...even then you may have trouble sealing the head together as there is very little gasket in that area due to the differences in head and block.
you'll also need to tap out the block for the rb26's larger head bolts, a machine shop can do this for you if you're having the block bored anyways.
dunno if you would be interested but i have an rb25de block from an r32 which you can use all your forged bits in and bolt the rb26 head on without any welding or modifications, just tap for larger head studs...block is already tapped for a turbo setup and is in good nic.
pm if you're interested, i'll make you a good deal as i need it out of my garage.
leekim
Car: 1995 240sx
can you tell me a lil bit more about this RB25de block. like im i getting it with a crank and the condition. you could e mail me a price @ [email protected]. Also i wont have to do any modding to the head or block besides the bigger studs?
