Darius »
https://forums.nicoclub.com/darius-u5470.html
Thu Jul 09, 2009 8:29 am
You can check for a leaky injector by disconnecting the injector and ignition harnesses and turning the engine over. If the plugs are wet when you pull them, then you might have an issue with the o-ring(s) on that injector. I still don't think it is the cause of the idle surge because that would only cause it to bog a little and sound like it was missing a cylinder. Surging idles are usually the result of MAF or O2 sensor issues where the ECU is trying to compensate.
rb25det250sx - your coil packs have been failing all summer. Replace them or upgrade. I'll sell you my old ones. They should work fine on your setup.
