Ok, im gonna say this first off, and expect me to be harsh if you dont listen
I dont want to hear i think, IIRC, maybe, possibly, etc etc
Car is a WGNC34 IE Nissan StageaHas an rb25det automatic 4wd setup.
I am doing a manual swap be it a 4wd or 2wd swap
I know how to do it 4wd swap adn remove fronit driveshaft, however i need to know about the RWD swap
What do i need for the R33 GTST transmission swap, if it will even work on an AWD prepped block.WIll the R33 GTR Pedal/master cylinder/and slave work with the type of clutch the r33 GTST uses.
Will the rear driveshaft mate from the the r33 GTST to the stagea rear end.
thanks
