Rb25det Automatic Transmission on RB20det
shinaka
Car: S13 Silvia
My rb20det is modified and the stock transmission is starting to give way..was wondering if the rb25det auto trans can work?
How much stronger is the rb25det auto trans in terms of hp?
How Difficult is a swap?
How would it affect drivability?
Help Appreciated
dickie
Car: Killer Turtle
is this for use on a 240sx
Oatmealman
Car: 2011 ford f150 fx4 5.0 master race
he's in spain.I don't know if they got skylines but i doubt it
JimmyMethod
Car: 97' 240SX SE
eh?
He's in Trinidad not Spain... lol ( P. O. S. is the capital of Trinidad)
From what I remember the auto transmission's are the same...
Joe
eh? wrote:He's in Trinidad not Spain... lol ( P. O. S. is the capital of Trinidad)
ehhh i dont think they are
i have an auto rb25 transmission in my garage, its a MONSTER. as for the swap...somehow i think it would be a WIRING NIGHTMARE
Lamodamo
Well Gentlemen, I have a RB20det mated to a RB25det auto transmission in a C32 laurel medalist...Only difference was the converter and flexplate, the RB20det transmission had a 3 bolt converter and flexplate as opposed to the four bolt converter and flexplate from the 25det.Will definately be able to handle more pressure than the rb20det transmission. My suggestion is to run an external transmission cooler after the stock one (radiator) and run good transmission fluid (redline or quakerstate).
Oh, i'm also in Port of Spain Trinidad.
shinaka
Car: S13 Silvia
I am from Trinidad..the capital is Port of Spain
shinaka
Car: S13 Silvia
How does the different gear rarios affect the cars performance?
Can the same rb20det auto trans harness be used on the Rb25 trans
by the way thanks for the help appreaciated alot......
Lamodamo
shinaka wrote:How does the different gear rarios affect the cars performance?
I haven't really had time to do a comparison between the two since the rb20 transmission was slipping when i got the car. I have the stock RB20 transmission harness still, I just used the 25 ecu with it. The transmission pulls the car hard from low down, second gear even breaks traction at change.....What I do need to change though is the rear end, the stock c32 rear end is crap. I've got a rear suspension frm the c33 laurel, disc brakes, teflon bushings, lsd diff etc that is going up very soon. Will let you know how it works. BTW, what part of Trini are you from?
shinaka
Car: S13 Silvia
thanks for the info.....I'm considering using the rb25det auto trans for daily driving and still be able to hold the power reliably when doing some drag racing...can the rb25det auto transmission hold about 350whp?
BTW I'm from St Augustine
Gold Digger
Car: Current:
2011 Infiniti G25X
Former:
1995 Nissan Skyline GT-R V-Spec Midnight Purple
1990 Nissan Laurel Club S Turbo Two Tone Pearl
Lamodamo wrote:Well Gentlemen, I have a RB20det mated to a RB25det auto transmission in a C32 laurel medalist...Only difference was the converter and flexplate, the RB20det transmission had a 3 bolt converter and flexplate as opposed to the four bolt converter and flexplate from the 25det.Will definately be able to handle more pressure than the rb20det transmission. My suggestion is to run an external transmission cooler after the stock one (radiator) and run good transmission fluid (redline or quakerstate).
Woot! Another Laurel Owner. I got's me a C33 Club S Turbo. To bad you didn't live here in Japan. Let's see the pics....
