S14-NEO »
https://forums.nicoclub.com/s14-neo-u25945.html
Tue Sep 29, 2009 1:07 am
NEO cams are definately different due to the fact that the NEO has solid lifters from the factory. the exaust manifolds are the same though so if you looking for an aftermarket version you can get any one you like and it will bolt up just the same. if you looking for an aftermarket intake plenum like a greddy you will have some issues there . the NEO throttle body wont fit, the IAC valve is also different on the NEO and the fuel rail on a NEO uses top feed injectors like the GTR. those things are all able to be gotten around though and the greddy manifold can and will work on the NEO, i know im using one on my NEO.
