Just curious as to what AFR gauge youre using (or were using) initially?DrifterProdigy85 wrote:After fixing my boost leaks and exhaust leaks, ive finally gotten a solid AFR reading. Currently its 11.5 AFR @ 10psi and 12.5 AFR @ 13-14psi. Is 12.5 AFR still safe with the stock ECU?
Modified by DrifterProdigy85 at 8:52 PM 10/1/2007
NGK iridiums?blurrbosi wrote:iridiums work fine for me. Stock ecu they did sputter from time to time when @ high boost. ie: above 11psi...
