RB25DET ACL Rod bearing clearance spec?
ANVIL
Car: RB25DET S13.5
Looking to install my rods in my rb25 but i need the bearing clearances... anyone know or show me where to look it up ?
RRRRB
Car: 98 RB powered S14
You ask more questions than anyone ive seen..
Generally with ACL ive gotton .0014-.002
i like anything between .0015-.002 have had great luck with that clearance... the Factory clearance is a little tighter than that..
ANVIL
Car: RB25DET S13.5
Lol
Im just overly paranoid and like to double and triple confirm stuff sometimes. Just had a lot of bad luck with my car.
Appreciate the replies though thank you
ANVIL
Car: RB25DET S13.5
What do you think of .003 clearance for the main bearings? That was a common number I came up with when searching and mine came out to right about that on each one
ANVIL
Car: RB25DET S13.5
So I re-downloaded the FSM and found that the copy that I was using was missing a lot of pages
I found this page which shows the clearances to be .020 to .040
ImageI know this is Factory not ACL butt where did you look up the specs for those numbers
RRRRB
the measurements i suggested are in Inchs
the ones in the manual are in MM
BIG DIFFERENCE
ANVIL
Car: RB25DET S13.5
Yeah i just realized that shortly after my last reply as we both weren't specifying units. Lol
