rb25det 5spd transmission questions
dcdrifter
When I bought my rb25 it had an automatic transmission and I put a 5spd transmission on it. Is there anything else I need to change.....ecu?
Also I need the clutch cover or flywheel cover or whatever its called....any suggestions
Thanks
Ramius83
Car: 1995 240sx SE
Ok, you'll need the following:
RB25 flywheel or 90-96 300zx Non-turbo flywheel90-96 300zx Non-turbo clutchRB25 slave cylinder (stock slave cylinder may work, but we don't know yet)90-96 300zx Non-turbo Pilot bearing90-96 300zx Non-turbo throwout bearing
I am pretty sure that is about it. Basically, if you buy a 90-96 300zx non-turbo clutch kit, it will come with the throwout bearing and the pilot bearing. So all you need then is the flywheel. And, you can buy a Fidanza or other brand lightened flywheel for the 300zx non-turbo as well.
As for the computer, you do not need a 5-speed computer, but it will be throwing a code or two because of not having the automatic transmission. And you also may have a harness connector or two left over that the 5-speed does not require. You can sold the computer error/code problem by getting a 5-speed ECU, but it is not required.
FrostyRB
Car: cars, bikes, atv's
I've got an extra rb25det trans if you need one. Might also have the stock clutch, pressure plate, & flywheel.
BigSLiKRB25
Car: 94 240sx
I have a 5spd trans and a clutch, and preesure plate. I will however need a throwout bearing. Does anyone know of one i might be able to purchase?
cyris3d
how much 4
FrostyRB wrote:I've got an extra rb25det trans if you need one. Might also have the stock clutch, pressure plate, & flywheel.
how much 4 the transmission
FrostyRB
Send me an e mail for price. [email protected]
gawdzilla
Car: none
does the KA slave cylinder fit on the RB25DET trans?
Joe
DO NOT FORGET TO CHANGE THE PILOT BUSHING.
its very important to change it to a 5 speed one.
