As Nick said, the Z32 MAF provides better resolution than the RB25 MAF can. The Z32 can provide airflow measurement up to around 450 to 500bhp, the RB25 to only around 350 to 400. With the E-manage you have the option to add a MAP sensor which will allow you to control fuelling beyond the MAFS limit. I had a Z32 MAF from my previous engine so I decided to use it on the RB.
I'm actually using the E-manage to control the Z32 MAF in a 'blow-through' arrangement where the MAF is actually sited between the intercooler and the throttlebody. I trialled it on my CA18DET for 5 months and it worked well, hopefully it should work just as well on the RB too. Tomorrow I'll start mapping it and running the engine in prior to the cars first event on Sunday 21st.
I'll post up some pictures of the engine after the event and you'll see why we went 'blow-through'. Can't reveal too much at the moment
