Rb25det 240sx Differential
r33240sx
Car: 1992 Nissan 240sx
Hey Every one I am new here and i have a problem with my 240sx its a 1992 with the Rb25det swap. The problem is that while im driving on the express way im only going 55mph and my car is at 4000rpm in 5th gear does anyone know why it does this or has anyone had the same problem. Any pointers will help. Thanks.
Carryl
is you ka tach calibrated correctly for the 6cyl?
s13point5
Car: 89 240sx
Carryl wrote:is you ka tach calibrated correctly for the 6cyl?
i bet thats the problem
BoostFab
Car: S13cp, S13fb, S14z
r33240sx wrote:Hey Every one I am new here and i have a problem with my 240sx its a 1992 with the Rb25det swap. The problem is that while im driving on the express way im only going 55mph and my car is at 4000rpm in 5th gear does anyone know why it does this or has anyone had the same problem. Any pointers will help. Thanks.
you can also swap out the diff w/ a j30 or a q45 for a higher top speed final gear.
silviasgp06
Car: 95 Nissan Zenki RB25 Powered
wow, if this is just the tach not being calibrated for the 6cly cause that would make me really worried for you since you missed it while researching what is needed for an RB swap.
........you did research first right? cause this one thing that is discussed that happens, but maybe you just missed it(makes me wonder what else you might of missed). I sure hope its just a small thing you missed..... and not that you knew nothing about the swap going into it.
if its something completely unrelated then ignore my bs above.
have fun!
r33240sx
im not sure about the tack calibration cuz i never heard or read about that but i can hear the engine reved up so i figured it would be something else.
r33240sx
thats wat i was thinking but i didnt know which diff to get r they both the same or which one is better. and if its not that i was planing on getting it anyway cuz the one i have isnt that good.
WhatsADSM
Car: 1998 240sx
Wow...
Yea it really sounds like it is the tach. Put a real tach on there or adjust your stocker.
What you think is 4000 is really more like 2666.
Have you ever hit the revlimiter? If so I'd bet you wrap the tach before you hit the limiter... That should be a clue that it is off
