RB25DE NEO AWD Turbo question
vin diesel
Car: 99 328i
so i got a rb25de neo for free, it came out of a r34 gts4 with 10k on it.
and i had some questions for when i turbo it. i know the CR is 10:1 because of the taller pistons so is there a company that sells a thick enough head gasket to give me a 9:1 or 8:5:1 ratio. and because it is awd when swapping the rwd pan will i run into any issues, or is it like the rb26 oil pan swap. and if anyone knows of good 25de-t neo build threads i would love to read up on them
toadx8u
Car: 1975 Datsun 710(coming soon F20C)
1993 240sx Vert DD
1995 240sx GT3788 RB25DET
1996 240sx LSx 5.3L
2000 F-250 Crew Cab Diesel
2004 Honda RC51
dont waste ur time...buy a set of aftermarket forged DET rods and pistons and just call it a day...then slap on a turbo mani...and drive on...but if u insist on de-t get up with the aussies on skylinesdownunder or skylinesaustralia
vin diesel
Car: 99 328i
i already have the manifold, and i was hoping not to pull the internals because of how little miles are on the motor. and for my ecu options am i better off with a neo 25det ecu and nistune that or get something like a power fc.
Cjmartz2k
Car: Hunting for a '89 GTR now
Also, putting on a thick head gasket to change your compression ratio, especially that much, is a VERY BAD idea. It's not that simple. There are other things that factor in to an engine's tendency to knock besides compression ratio like squish and quench height, both of which you will totally screw up installing that thick of a head gasket.
toadx8u
1993 240sx Vert DD
1996 240sx LSx 5.3L
2004 Honda RC51
cast internals are weak...even on the DET engine higher comp is not gonna help at all...and im selling a power fc with data logit if your interested...
R32ONP
Car: R32 Skyline GTS-T
RB20DET
man plus ts have such a bad name lol..iv seen some done and they do last as long as u aint detting the s*** out of it and u have supporting mods...not just a turbo wacked on etc...the question is tho if ur gona pull the head off and do headgasket (which i beleave too is a bad idea) y dont u just wack some good condition second hand RB25DET pistons in and a proper DET headgasket??? least ud have the reliabilty and with a DET ecu it would all be fine???
vin diesel
Car: 99 328i
i think im just going to run a 1.8mm hg, and nistune. should lower my compression some and ill get a solid tune on it
R32ONP
RB20DET
why did ya start the post if ur not willing to listen to any of us and u oviously had ur mind set allready on wat u were gonna do...which in my opinion wont last long at all
vin diesel
Car: 99 328i
R32ONP wrote:why did ya start the post if ur not willing to listen to any of us and u oviously had ur mind set allready on wat u were gonna do...which in my opinion wont last long at all
i just am not going to pull my internals, i am not going to run high boost and im not going for crazy hp. the 1.8mm head gasket isnt too aggressive but it will allow me some more room for boost.
but if i do decide to change my internals i will go with forged after market. I will be working on the motor all winter and i will decide after looking at how much im going to spend
R32ONP
RB20DET
the thick headgasket is a waste of time in my opinion....for not much more u could put DET pistons in and a DET headgasket and be done with it....why pull it apart and do a half a** job??? ull be like dam i wish i listened to that guy wen u pull it apart the second time lol...and y get aftermarket forged pistons if ur not doing anything crazi thats just a waste of money
StricNyne
i say run it on DE internals, just dont run high boost, and that thing will be pretty quick, pulling apart a motor is super expensive. what turbo are you running stock ? what inj ? a solid tune will be the defining call on realibility on the setup
vin diesel
Car: 99 328i
StricNyne wrote:i say run it on DE internals, just dont run high boost, and that thing will be pretty quick, pulling apart a motor is super expensive. what turbo are you running stock ? what inj ? a solid tune will be the defining call on realibility on the setup
I will be running. A gt30 or hx30 @ 1 bar. With 600cc injectors.
StricNyne
just keep afr down and no detonation, and de internals will be ok, idk if neo has same ringland issues as r32 and r33 though maybe look into new pistons in future
