Andreswithag20 »
https://forums.nicoclub.com/andreswithag20-u43839.html
Sat Feb 06, 2010 8:09 am
Hello all. I'm in desperate need of a project! I was planning on doing an m45 v8 & trans into a 1st gen Q45 (may still do it in the near future) but I stumbled across a rare 4x4 SUV with a dead ford motor (would have removed it anyways) but the truck is in excelent shape in and out... and I thought it would be interesting to swap an rb neo engine. A few concerns/questions i have are the lower torque issue cuz this is a heavy huge suv similar to the range rover. Also, can i use the skyline automatic transmission? Or should i use a different automatic trans like from an exterra? What work would be involved in both options? What transfer case can i use? Finally, what engine mods would be required to make the engine work in a heavy suv and possible some offroad use? thanks
Edit:
I'm starting to consider using a vq, vh, or vk engine instead since parts and trannies/stansfer cases are more easily available and installed. Plus those engines are aluminium and not heavy iron like the rb
Modified by Andreswithag20 at 11:26 AM 2/6/2010
