Rb25de computer problem
rb25r31
Car: R31 Ti with Rb25de long turm hopes to be 3L bottom end with turbo
Hello guys have a little... SORRY BIG problem have just put Rb25de conversion in my R31 and after 2 weeks of trying to get the busted started i found out that i had a BLOWN risister inthe computer.
would it be safe to change the 10c resister or should i shut my mouth and get a new ECU for $150
also does the numbers on the ECU make a diffrence and can the Auto computers run a manaul engine
thanks help would be much appresiative
Vkoslak
Car: 1992 240SX SE rb26dett, 2004 Subaru Forester
I would try the resistor first if its cheap and you know how to do it. At this point the ecu is useless, you can't f it up much more. $150 aint bad for an ecu either.
Auto computer can run a manual, but its going to reduce power when it thinks you should shift. Timing will probably be different as well. (20 instead of 15 afaik)
themadscientist
Auto computer can run a manual.
rb25r31
Thanks i might try get a risister and have a go what is there to loose..... and already stuffed computer and i ill get the other computer for a spare if the risister does work.
thanks for the info use have been helpfull
Joe
Vkoslak wrote:Auto computer can run a manual, but its going to reduce power when it thinks you should shift. Timing will probably be different as well. (20 instead of 15 afaik)
it does not reduce power. and there is a workaround for the timing. involved grounding a wire on the ECU (park/neutral position switch if im not mistaken)
<- auto ECU on manual RB25.
