RB25 -> Z32 ECU Swap Help
Brennannn
Car: 1995 240sx
I swapped to an eprommed Z32 ecu, and have had problems finding the WOT Switch pinout. Help anyone?
http://forum.nistune.com/download/file.php?id=894
1 KS - I took care of this electronically
2 O2 inputs - I took care of this electronically
3 PS switch - pin 19 is disconnected
4 Full throttle switch - Z32 has one, RB25 doesn't. Disconnect. HELP
5 FICD - pin 33 is disconnected
6 fuel temp sensor - I took care of this electronically
7 injectors - 105 -> 110, 110->105, 112 -> 114, 114->112 - Done
Brennannn
Car: 1995 240sx
anyone?
Brennannn
Car: 1995 240sx
I'd like to add a note. People say swapping the injector pinouts work in theory, it doesn't. My car doesn't run right after doing the swap.
Klits562
Car: white s13 coupe
Brennannn wrote:I'd like to add a note. People say swapping the injector pinouts work in theory, it doesn't. My car doesn't run right after doing the swap.
At the top of this forum theres a thread about rb wiring harness
wire-harness-conversions-need-a-good-so ... 44853.html
the guys username is carl H it appears he knows alot about rb wiring, maybe he can help you.
Carl H
if you repin the harness correctly the z32 ecu works flawlessly, a customer of mine had me chip a z32 ecu at the same time I converted his harness with intentions of switching over to that after it was up and running on stock ecu.
ends up stock ecu was fried and car was at a no start situation, i repinned the harness for the z32 and after some trouble shooting (stock ecu fried a fuse) it fired up first crank.
