240drfter »
https://forums.nicoclub.com/240drfter-u102266.html
Wed Mar 28, 2012 1:14 pm
hi, i hope somebody has seen this problem before....
as it turns over it just hits on a few cylinders then dies...
if you continue turning over it wont hit againg but if you let of then turn over again it hits on few and dies...
i pulled cas out and spun it and injectors are clicking
have fuel pressure gauge hooked up and theres pressure there.
one thing weird is that it wont turn over with key ive been jumping starter....
its a 94 vert that i converted from auto to manual so it may have something to do with that...
another thing is that the fuel pump doesn't come on with key i just ground signal wire at fuse box interface to turn on
but what common thing controls both the fuel pump and the starter because i think the problems lies there but i've looked and not found anything
i done the auto wiring and the top works and when i jump inhibitor switch i hear the relay click..is there something that i may have missed
any help or suggestions will help...and if anyone needs further info or pics just ask.....ready to drive this thing
when i pulled stock motor out it cranked and drove...so this isn't a pre-existing problem
if you spray ether in tb the car will stay running...it's like it cuts off injectors or something
