DropTopRB »
https://forums.nicoclub.com/droptoprb-u61454.html
Sat Apr 28, 2007 3:00 pm
Rb25det into s13, im not getting any spark, the ecu isnt even putting out a signal. Ive checked everything at the ecu, its got all the grounds and ignition signals its suppost to get. The coils have both power and grounds to them. The only thing that i noticed was there was no signal into the ecu from the crank angle sensors when cranking the engine, which i believe would prevent the ecu from sending a spark signal. The only other thing that i noticed was when you unpluged, and pluged the CAS on the front of the engine with the ignition on it sounded like the fuel pump, and fuel pump realay were ingaging, are these systems somehow liked together to do this???? I also noticed that when the ignition is on, the injectors have power to both wires, is this normal????
Any help is greatly appreciated, ive been trying to get this thing running for a month now and im about to give up on it. Thanks!
