Shocker »
https://forums.nicoclub.com/shocker-u18595.html
Sat Jan 14, 2006 3:32 pm
yea im going to try the battery thing once my charger its charged, im not sure if the battery is dead tho, i do get lights and seat belts, door chimes work and all, im gonna have to try later once the charger is done charging. just to check on grounds, theres the battery terminal ground to the block, alt ground, the starter is grounded to the transmission by the bolts, and the two grounds comming from the upper harness in front of the intake mani, any im forgeting?
