RB25 with RB20 transmission... what driveshaft???
NismoJunky
Car: 1993 240sx Hatchback. RB25DET, 5 LUG
I just put a RB25 in my s13 hatchback. I got a good deal on it because is has a RB20 transmission, I was under the impression that I could use my stock drive shaft like the RB20 guys, but I tried to put it in, and its too long.
are there any guys on here running the same set up as me? if so what did you do about a drive shaft?
Neejay
Why not get a custom one made?
BoostFab
Car: S13cp, S13fb, S14z
NismoJunky wrote:I just put a RB25 in my s13 hatchback. I got a good deal on it because is has a RB20 transmission, I was under the impression that I could use my stock drive shaft like the RB20 guys, but I tried to put it in, and its too long.
you can use the same s13 driveshaft. just remove or trim off a little bit of the gold dust cover at the tail of the transmission.
IronMonkey
what kind of mounts did you use? i believe the stock driveshaft only work with the skyline crossmember...
NismoJunky
I used some mckinney copy cat mounts from eBay
OpeLok
try using a different stock driveshaft. I forget which one is shorter... non s14 abs, or with abs.
NismoJunky
BoostFab wrote:you can use the same s13 driveshaft. just remove or trim off a little bit of the gold dust cover at the tail of the transmission.
HELL YEAH! that worked man! haha, I feel like a dumbass.
BoostFab
good job, i'm glad that helped. now get that btich running...
