SullivanRacing06 »
https://forums.nicoclub.com/sullivanracing06-u63212.html
Sun Jun 26, 2011 7:06 am
hey nico its been a long time since ive been active on here, but im back!
just did a r33 rb25det swap in to a customers s13 and im having a really odd problem...
the stock rev limiter on a r33 rb25 should be 6900?
this motor will rev past that and keep going, BUT, its acting like the hard cut limiter is trying to control the revs and cut fuel, well its not cutting enough because it keeps revving into a lean condition.
i have swapped mafs, set the tps, swapped coolant temp sensor, boost leak tested it,
the motor set is 100% stock. the ecu is 100% stock. i removed the engine from the clip, no mods what so ever.
the only thing i have not checked yet is the ecu..
dont have a extra to swap in at the moment..
this happen to anyone else?
thanks!
