RB25 wiring gurus needed please
Paulpen
Car: Nissan Onevia with RB25
Im quite a lurker, reader and searcher but less of a poster but hoping that wont matter :
Long story but here goes
18 months ago I did a RB25 (series 1) conversion into my S13. It was my daily at the time and I needed it to work so got someone to do it that was supposedly an expert at it.
I did the swap and it didnt start. No power to injectors or coils so I got it running.
Skip foward 18 months. Im now breaking my S13 and building a Onevia that the RB is going in. I cleaned all the unwanted wires from the car loom and then get to the engine one. Untape it etc and O.M.F.G its a mess.
Ive already sorted out the bodged pins in connectors but have a few questions that I cant really sort without looking at another loom or someone knowing it :bawling:
So here is what I know :
The R33 harness connects to the dash harness at one point so mine was repinned to fit my dash harness. Currently I have 4 wires in it which ive traced as follows :Yellow/red - splits into two wires and goes to the tacho readout wire in the bay and the ecuYellow/green - to the ecuBlue/black - Temperature gaugeOrange -> grey/red - ecu
And thats all I have in that connector as per pic
Im guessing this is the R33 version of what im using (but with more wires)strange thing is that I have 3 wires going into this from the engine loom so they go nowhere !Ive traced them so here goes
Black - goes to a purple inlent manifold plug - think its AAC (air con idle up) ?
Light blue - Goes to a gray connector with an orange insert, not sure where but possibly front of inlet area. Heres a pic or two as im crap with words
Blue/white - splits off into 4 wires after about a foot. These then go to a coil pack plug, what I think is the VVT (first pic below), the oxygen sensor and what I think is the boost solenoid (second pic below)..
If you are still reading then thankyou
The thing I find strange is that the car seemed to run fine on stock parts but did overfuel a bit and pulled 285ish on standard boost.
Help very much welcome
Paulpen
Traced every wire from the ecu connector to its end tonight and here is what ive now got. I used the following guide but not sure if its correct or my loom is missing alot of things :S
I made a table of what ive got and where it is and uploaded it here as cant seem to get the table to look correct any other way
MEGAUPLOAD - The leading online storage and file delivery service
eh?
http://rbforums.org/pics/rb25diagram.jpg
http://wiki.r31skylineclub.com...s.jpg
http://paulr33.skylinesaustral...g.jpg
Paulpen
Well after alot of time and help I think ive got it all done correctly now
Just a question about the coil pack loom though - is it meant to have 2 earth bolt connectors ? One goes the the white plug and one comes from inside the tape going to the pack connectors ?
Paulpen
Anyone ?
