With all the research i did on rb 240 swaps, i always read that it is such a huge difference, untill i bought an rb25 240. granted it has stiff coilovers but going around tight corners isn't a WHOLE lot different than my fd rx7. like kamin said, unless you do some serious cornering or drive your car hard enough then youre not really going to notice much of a difference.Kamin wrote:for years...and years....i have tried to fight the weight balance bull**** myth. years...
the only people who say it hurts the handling of the car, have never driven a RB powered 240.
yes it does affect the handling, but its just a new characteristic of the car. no better or worse. just something you have to adapt to. I had a RB25 in my car for years and did both grip and drift with it, relatively successfully, and i never had an issue with the "balance"
bottom line is 99% of the people who talk **** about weight balance and how they want a "perfect" 50/50 ratio will never drive their car hard enough to notice a difference.
i love using this analogy because its the most cut and dry one i can figure out. your cars balance changes as much with an empty vs. full tank of gas, as it does with a RB25 swap.
ok in your sig is says soon to be rb powered. sooo do you own a rb powered s chassis right now while you make those claims?Adrian gt wrote:i'm not going to lie, it changes the car, odes it change a lot? not that much, i do like the response of the sr in the car but that also has it's draw backs like understeer. for the most part it will reduce handling a little but af for the whole 50/50 thing, that's for people who can't tune suspension. look at mid engine cars they are never 50/50 but they handle great. same can be said for the rb in a S13-14 might be a little nose heavy but you'll learn to drive the car and some drifters like the heavier nose for stability in the front while the back's out.
So, 14 gallons of gasoline do not weigh 120lbs, silly. 14 gallons of gasoline weigh roughly 88.2lbs! Sorry guys, I'm taking chemistry this semester.Kamin wrote:14 gallons is ~120lbs
"I've never seen so many DEAD HOOKERS in all my life!"Lord knows I have..Darius wrote: Just equate it to a dead hooker in the trunk.
yeah, i read that thread, funny stuff.Coolwhip wrote:I feel like pulling out the sock jokes but... oh what the hell.
I have yet to see that too much heavy cotton used in the toe portion on the rb socks throw off the equalibrium of the wearer. k, that's all.
