rb25 water pump
rhd240
Car: 1989 240 sx
popped a headgasket on the 25 and need to know what the visual difference between the oem and n1 water pump? and is cometic a good gasket for rb's ?
Gabes13
Car: rb20det s13
N1 pump has 6 bigger fins while oem has 8 smaller fins. Unless your resurfacing the head and block an oem head gasket might seal better.
rhd240
Car: 1989 240 sx
thanx . i just didnt want to get ripped off and by an oem at n1 price. i want to run the cometic head gasket because i want to run more boost and dont want to pop another. mine popped when the wastegate vacuum came of and went to about 25 psi. u wouldnt happen to know a part # for the n1 would you ?
l0nestar
Car: 1993 Nissan 250SX
2004 Toyota Altezza
1963 Chevy Impala SS
The OEM head gasket is more than adequate. Also, they seal better than most.
OEM Head Gasket - Raw Brokerage
Also use the OEM water pump.
Water Pumps Raw Brokerage.com
Roughly Two and a quarter shipped and your done. Also, make sure your head and deck are both straight-edged. The OEM gasket will give you a little bit of leeway if it is not exactly square.
rhd240
Car: 1989 240 sx
why oem water pump and gasket? i live in the south now and im triing to make it run cooler. and how much boost will the stock gasket hold? im putting a precision sc 61 turbo, 740 injectors and aem. im shooting for about 450whp but want it to be ready for more. i am also gona drive this car just about every day so i can get out of my wifes honda so i need it fairly reliable.
gijoe392003
Car: 1989 Nissan 240sx Coupe
2008 Nissan Titan
You have to be careful when choosing an after market head gasket because it could change the compression, thats why most. Like said before, if you want to use a metal head gasket, make sure the deck and head are flat. I doubt you need more than OEM for the water pump, just be sure you are running a good rad and fans. Honestly though, search some more and you find better information.
l0nestar
2004 Toyota Altezza
I suggested the OEM gasket because, they can hold a lot of pressure, and are more forgiving than MLS gaskets. Also, as GIJoe said, with the MLS, you can modify the CR.
The OEM water pump because, unless it is a dedicated drift or road-race (sustained high rpm) car the OEM can actually out perform the N1 water pump.
Also, don't forget a set of uprated ARP head-studs. ;)
Ducting and a decent radiator will make the biggest improvement. (although, a clutch fan is far superior to e-fans - if you can fit it.)
rhd240
Car: 1989 240 sx
plan on the arp studs. dont have room for the clutch fan but i am runnin dual 12in fans, koyo radiator. thanks for the info
