Postby
silviasgp06 »
https://forums.nicoclub.com/silviasgp06-u61439.htmlWed Mar 26, 2008 5:52 pm
ok i have this whirling noise coming from the intake cam area at low idle and goes away past 1100ish rpms.
ive have a few tell me its the vvt solenoid, acting and one gave me specifics on what he thinks it is.
he said that something is up with the ground or connection with it. He said theres a connection that causes the solenoid to not actuate when the transmission is not in neutral.
Postby
matafied »
https://forums.nicoclub.com/matafied-u53812.htmlThu Mar 27, 2008 2:42 am
its vacume traviling through your pcv valve maybe? pull it out of your valve cover and block it off with your finger and see if it gose away, Just a thought.
