Postby
fairzdrift »
https://forums.nicoclub.com/fairzdrift-u58635.htmlMon Jun 23, 2008 5:42 am
Are there any differance im planning on swaping a rb25 into my 89 coupe using the syko performance mount kit
it needs the crossmember so does anyone know if a rb26 would work since the place im ordering it from will through in a rb26 crossmember for free with the swap im geting because he has it laying around ?? thanks BTW anyone use this kit before ?? reviews would be helpfull Thanks again
Postby
Coolwhip »
https://forums.nicoclub.com/coolwhip-u13264.htmlMon Jun 23, 2008 6:29 am
Yea, as Boostfed said, the RB26 xmember will do you no good. if you actually look at the mounting points and its configuration it's defentantly out of the question.
Postby
ST240 »
https://forums.nicoclub.com/st240-u459.htmlMon Jun 23, 2008 2:02 pm
BoostFab wrote:the rb26 crossmember will not work. it is different, it was designed for different front suspension. get the rb20 or 25 crossmember instead
Just curious, how do you make an r32 crossmember work with the rb26?
